Does anybody actually own a Viewsonic VP2030b?
Brahmzy
584
28
I'll be coming from a 21" Viewsonic CRT and I'm really worried about ghosting and blur...
The VP2030b is rated at 8ms. I also have a Viewsonic VA912b that's rated at 8ms and it's good, but not good enough for my gaming. I get a little too muich ghosting with that monitor. Will the bigger Viewsonic be the same way?
Are there any other 20.1 4x3 LCDs that are faster than 8ms? Will there ever be?
I need the bigger size (1600x1200).
Please help - thanks.
nullpointerus
1,326
I can't answer your question, but you do have that VA912b hooked up with a DVI-D cable, right? A VGA cable (or a DVI cable plugged into a VGA port with an adapter) could make the ghosting much worse than normal because of the unnecessary digital->analog->digital conversion.
