Does any case out there have dual 120MM fans and a normal HD cage?
GreatDaleness
289
Other than the Antec 3700AMB, is there any case that has dual 120mm fans and a normal, not side mounted, HD cage?
SithSolo1
7,740
11
I can't think of one off the top of my head but why would you want that?
Found this over on Newegg. 120mm intake, 92mm outtake, normally oriented HD cage.
Goatsan
123
well the new antec P160 has seperate hd bays to make it easier to move them around, and two 120mm fans
Blooz1
621
The Compucase LX-6A19 has what you're looking for. This case is sold by Coolcases.com as the D8000, but I got mine from Directron for about $40.
This is the same chassis as the Antec SLK-3700 without a door on the front bezel. It's heavy steel, and has a ton of room inside. The removable HD cage has grommets for mounting drive to cut down on vibration and noise.
THUGSROOK
11,847
Originally posted by: GreatDaleness
Originally posted by: THUGSROOK
how about 3x 120mm fans and room for 5 HD? (more if you add a cage to the bottom)
link
This looks like a great case! Anyone have this?
i do ;)
it really is a great case, and for all reasons.
plenty of room to work~
removable MB tray with PCI slots~
excellent cooling~
baybus for controlling fans~
easy wire hiding~
easy side panel removal~
also, the case is white, not some fugly off-white.
Gravity
5,685
What about the antec sonata? I just started building one for a friend. Two 120mm fans, one in front and one in the rear plus some fantastic setups for HD's.
It's very impressive.
GreatDaleness
289
It has a side mounted HD cage. This greatly reduces the cooling that your HD gets. It also reduces the amount of air your case takes in.
? (=Þ)
does the case from directron come with that front panel USB/sound unit? or is it an accessory you have to purchase? did it come with any case fans? and lastly do 38mm thick fans fit in the front/rear?
SithSolo1
7,740
11
Two questions.
A) How in the world does that reduce the cooling of the HDs? There is more space around them so the airflow would be increased.
B) How does it reduce the amount of air coming into your case?
