Thanks for the update. Guess I will have to look at the PS sometime and see if I can determine how the fan speed is controlled. As far as the PPC fan, I already have several around. I have been ordering them on and off, and if I knew how many I ultimately needed, I would have just ordered a case to start with. You are right, they are pricey, but I think I have one in an AT PS that I could swipe and replace into this PS. But I had better check out the Speed Issue. The first thing I did when I got my SX830 was to place PPC fans in all 4 positions, and I swear that the PS and sunon high output fan on the Pal 6035 (2cooltek) are louder than all 4 PPC fans combined. I would like to quieten this thing down some more, so I've got a Taisol 760092 on order, and I think replacing the Fan in the PS will be about as quiet as I can get....
BTW, with no case mods, and those 4 PPC fans, my inside case temps run about 10F above ambient room temp (measured with a Radio Shack inside/outside thermo with the probe stuck at the top of the case. Not exact, but I think I'm getting pretty decent airflow in there. I'm gonna put in some rounded cables also to relieve some blockage and see if I can clear some air passages in there (I've got floppy, ATA-100, SCSI-UW(68 pin), and SCSI-II(50 pin) cables. It's a mess right now.....)
