it all depends
if it integrates a powersupply into the body or has a seperate power brick
if the former, they will generate warmth... but i do not believe any LCD that has a seperate power brick generates any heat... my laptop's screen doesn't make any warmth at all
Yah....the lcd im stuck with now has an external power brick and no major heat generated anywhere, but it sucks having this huge power brick taking up space.....btw its soon to be a Samsung 940b wendesday.
