Does AIW Radeon 9600 Pro not support dual display + TV?
DJFuji
3,643
i can't seem to get tv out to function simultaneously with a dual display setup. When i was running a dual display using a GF2 GTS2 + GF4, i could run the standard dual display while also outputting display 2 to TV. Some websites claim it can't be done, others say it's fully supported. Has anyone else gotten this to work?
And if it isn't supported, why is "scheme" disabled in [display properties->settings->advanced->displays]? I would love to have a hotkey instead of navigating to display properties every time i want to output a DVD to the TV...
rbV5
12,632
Display Support
Two VGA displays simultaneously or One VGA display connected with a TV or VCR. Independent resolution and refresh rate for any two connected displays.
Link
DJFuji
3,643
doh...that's what i thought. Anyone know why "scheme" is disabled for me? For some reason WinDVD on monitor 2 chops off the top half of the screen. It's like it only shows the bottom half of the video. Don't know why. Monitor 1 displays fine.
monitor 1: 21" nokia @ 1920x1440
monitor 2: 17" "delta" @ 1024x768
rbV5
12,632
Have you tried "Theater Mode" for DVD viewing on the TV? Enable it on the Overlays tab.
