Does a WS LCD sound like overkill for me??
bcsman
My NEC 21" CRT is slowly passing on and looking at upgrading to a similar sized LCD. Here is what I will be using it for:
1) 65% internet surfing
2) 15% simple games such as solitaire, mahjongg, etc
3) 10% computer work such as defrag, scans, etc
4) 10% watching TV with my PCI TV card
I won't be watching DVD's or playing intense video games as I do that on my HDTV. Is there really any reason for me to get a 20" WS for what I do or just stick with a standard 20"?? Most of what I do would probably look better on a 4X3 aspect ratio wouldn't it?? And the scaling issues have me concerned also.
Looking at maybe the Acer 20" seems reasonably priced.
Any helpful advice would be appreciated as I am trying to make an intelligent decision in the next couple weeks. Thanks in advance!!
I actually think having a widescreen LCD is better for what you are describing.
First off you will save desk space, second it is easier to have side-by-side browsers/windows open on a widescreen, and finally since you will not be doing much gaming you will not run into any of the issues most people have with LCDs (ghosting, etc...)
I have a 4:3 LCD at work and a 16:10 widescreen LCD at home, the one at home is waaayyy better for surfing and office applications IMO.
Get a widescreen LCD, you will not be disapointed.
KT
I'd go with the widescreen unless the cost is way more. Other than that the scaleing problem isn't that big of a deal, check and see if there are any LCD configuration options in your video card settings. I have a laptop with a widescreen display and a Radeon x600 video card, I went into the options and disabled scaling this way if for example I'm playing an old game that doesn't have a widescreen resolution availble I'll just see pilar boxing(black bars on the side of the screen) aka the image won't fill the entire width of the monitor. I find this very acceptable and most people should unless they are screen zealots(or American, 😀 ) and have a problem if every centimeter of their screen isn't used all of the time.
If absolutely nothing else, you'll enjoy the space savings and cleaner (physical) desktop appearance.
Wow kind of surprised by the replies! Figured my usage would be more aimed at a non-WS LCD, but apparantly I'm mistaken! And actually from my LCD pricing, the WS's are pretty much less expensive than the non's. So I guess I win all around!
As far as the scaling question, do all LCD's have some sort of scaling themselves?? Or is it something I need to look at with each model?? By the way I have an ATI 9600XT video card. Haven't looked lately to see what options I have with this card.
Most LCDs do not have any scaling options, so your video card has to do this. I would suggest a 22" widescreen. I use a WinTV card with mine and it works fine - the winTV software scales the TV image with black bars on the side to keep it 4:3.
Besides the 22" widescreen in my sig, I also own a 20" 4:3 LCD made by Viewsonic. This is a pretty nice monitor, and I have also used the 20" Acer 4:3 LCD. The one I own is this one:
http://www.newegg.com/Product/Product.asp?Item=N82E16824116008
It is a very nice LCD for the price, and would have an effective viewing area larger than your current CRT. However, having used this LCD and the one in my sig, I prefer the 22" widescreen for overall computer usage, and worth the extra $40. However I do watch a lot of widescreen movies on mine. For your usage, the 20" non-WS Viewsonic and Acer would work fine, as long as your video card is OK with the funky 1400 x 1050 resolution.
I personally wouldn't get the 20" widescreen - I've owned one and felt it was too short, and the pixels were too small. I quickly got rid of it, in favor of a 20" 4:3 monitor, and then replaced that with the 22" widescreen.
Do you have the catalyst control center? if so open it and look in your display properties, if not you should still have a scaling option, for example I have a Notebook Panel Properties page and in that panel I can select to scale or center images.
