My computer had suffered a catastrophic failure two weeks ago and I am finally back online. I was testing an UPS when it happened. I had my monitor and computer connected to UPS and when I unplugged the power to UPS, instead of staying on without a transition, the computer rebooted. Shortly, I heard a pop from the computer and it shut off. I took the cover off to examine the situation and there was some smoke coming out of power supply.
I knew right there the 250W generic ATX power supply that came with my case was a toast. I bought an Allied 250W ATX power supply to replace it. When I plugged in the new power supply, it would cycle on and off rapidly so I knew it was more than power supply that was damaged. My hypothesis is UPS did something to damage the power supply and power supply destroyed the motherboard when it failed.
In the end, I had to replace the motherboard and the power supply. Does anyone know for sure if higher end power supplies have some mean of protecting the load against abnormal voltage should it fail?
