Does a fridge's ice maker use up much water?
LuckyTaxi
6,044
23
I made a post several weeks ago regarding this issue, but I just thought of something. well, the blue dial in the water meter spins slowly, but it does have a negative effect as my water bill has been more than $50 a month. it should be less than that. anyways, i hear water running throughout the house and NOTHING is leaking. the only thing i can think of is the pipe running to the fridge's ice maker.
Vic
50,422
14,337
Refridgerator icemakers only use a small amount of water. As much ice as you get out, that's as much water as they use. It sounds to me like you have a leak someplace, probably in a crawlspace.
LuckyTaxi
6,044
23
can't be ... i cant find any leaks ... no walls, ceilings or floors are damp. im calling the water dept out
Azraele
16,524
29
Have you looked at the bill? Our water bill is about that per month, but it also includes garbage, various taxes, etc. The amount we spend on just water is small.
TechnoKid
5,575
Maybe the meter is broken? Doubt this as you probably wouldn't be able to hear the water running from all the way inside the house. Wherever the water leak sounds the loudest is probably where its at. Also, everything from the meter to your house is your resposibility, not the water dept.
Vic
50,422
14,337
I'm saying that the leak (if any) is probably in the foundation or in the ground. You're responsible for everything past the meter.
$50 bucks a month is not outrageous though. My bill (water and sewer) averages $40-50 every month (paid $120-150 a quarter).
LuckyTaxi
6,044
23
mom pays about $30 and she runs a washer! i dont run my washer ... i went to the inlaws and their dial in the water meter doesnt move unless you turn on the faucet. mine moves whenever
BillGates
7,388
Are there any toilets that run constantly or faucets that drip? Maybe a neighbor tunneled into your basement while you were on vacation and is stealing water now? :)
LuckyTaxi
6,044
23
nope ... must find a plumber in the area. of course when i shut the main valve off the noise stops.
DT4K
6,944
As others have said, the ice maker only uses the amount of water needed for the amount of ice you need.
Otherwise, where would the water go?
It doesn't just disappear.
If you can hear water running, you have a leak.
Call a plumber immediately before you get too much water damage.
Squisher
21,204
66
Take some food coloring and put it in the tank of the toilets. Do not flush. Come back and see if the bowls have any color in them in 15 minutes.
Thegonagle
9,773
You have a leak. When your taps are off, and when the ice maker isn't actively filling (that takes mere seconds every few hours), your meter should not move.
If you have an underground sprinkler system or any other outdoor taps, have those checked thoroughly.
