BrokenVisage
In other words, you build up speed by stepping on the accelerator, then take your foot off it and you keep moving but gradually slowing down from no acceleration.. does this still burn gas?
Originally posted by: iamwiz82
Is the engine still running?
Originally posted by: Hyperlite
ah but the question is, do you use as much gas compression braking at 2500 rpm as you would maintaining 2500rpm?
Originally posted by: Savij
It's still running, still using the same amount of gas as it would at idle. The rate of gas consumption is controlled by the accelerator.
So the engine stops firing?Originally posted by: BD2003
The correct answer would be...as long as your car is in gear and not at idle, youre not using ANY fuel. The transmission is turning the engine...if the injectors kept injecting fuel it wouldnt slow down as fast as it does while still in gear. Might be different for older cars though. Drop it into neutral or on an auto coast for long enough and then it has to pump fuel in to keep it at idle.
If the transmission is turning the engine, what's turning the transmission?
Are you sure?Originally posted by: DougK62
Are you guys retarded? If the engine is running then it's using gas. Period. Even your manual trans car coasting in neutral to the stoplight is using gas. Engine running means gas is used.
LOL
LOL
LOL
Ill be as simple and concise as I can possibly be. Youre wrong.
