Originally posted by: JulesMaximus
Originally posted by: randay
Also on a related note, would it be more economical to engine brake more then regular brake, or regular brake more then engine brake. Meaning would coasting in neutral offset engine wear, gas vs maintenance? cost wise.
Coasting in gear doesn't cause any more wear on the engine than coasting in neutral.
I don't understand your question, you should really do both at the same time. Whether you do it all the was down to first gear is a matter of personal preference and how smooth you can do it (first gear is one of the harder ones to rev match and generally less forgiving if you misjudge).
If you really want to learn to do it you need to practice. Don't worry about the cost...you are going to wear out your car regardless and things will need to be replaced especially if you drive it hard. I'd rather learn proper driving techniques than sit there worrying about how many miles you'll get out of your clutch or throwout bearing. What's a clutch and throwout bearing cost? $500-600? Unless you really don't know how to drive you should get at least 100k miles out of one. That's about $.006/mile. BFD.
