does a car AC use gas?
Not directly.
The ac is powered by a pump that puts an extra burden on your engine which can cause the engine to use more gas.
Yes it does, most modern cars use a gas called R134a, but older vehicles, pre1993, use R12.
Does this answer your question?
The A/C itself doesn't run off gasoline. It runs off a belt connected to the engine, but takes power away from the wheels to run it. Hence the lower gas mileage if you run your A/C a lot while driving.
If you have a newer car riding with the windows up and AC on will give you a better MPG than the AC off and windows down. At least thats what my internet told me once.
I saw the best registration plate on a Lotus Elise a couple of years ago: R12 GAS
Owner must have thought he had a cool car 😉
Confused
You have an internet? I want one!
Also, I heard that you can't control how much AC your car produces, only how much of it goes into your cabin, so if you're going to use the AC, turn the red/blue knob all the way toward blue.
I have *two* of them!
I have a copy on diskette that I could send you.
The compressor will just run more or less depending on where you set the temp, but the AC can't produce any specific temperature...this is the case with pretty much any heating or cooling system
I heard that AC only has a 10% effect on your mph. The wind drag from driving with your windows down is something like 8%. So it's not worth it to go windows down over AC.
Originally posted by: MegaloManiaK If you have a newer car riding with the windows up and AC on will give you a better MPG than the AC off and windows down. At least thats what my internet told me once.
Don't copy that floppy!
You get the most power though with the AC off and the windows up. Not recommended if you have small animals or children in the car with you.
That's strange about the A/C sapping power, I've never noticed it.
In fact, I used to have a '98 Firebird, and whenever I floored it from a dead stop I'd actually stop getting cold air for a little while, as if the compressor was cut off.
Was I dreaming, or was the engine turning the compressor off doing heavy acceleration?
You weren't dreaming.
You needed the horsepower for acelleration, so the car turned off the compressor to get that power to the wheels instead of going to refrigerant.
mph? I assume you mean mpg... but that seems a bit excessive from my experience. I certainly haven't noticed a 10% decrease in summertime versus spring or fall. I would guesstimate a maximum difference of ~4% @ 24mpg (altima).
Mustangs do the same thing.
Turn on the vent, if you're going past 60mph you'll get a nice breeze.
Or get a rally roof vent, I've heard those are nice😉
Well, if an air conditioner uses X amount of power, then that amount is relatively small for a car with lots of power like the Firebird.
With my '97 Toyota Camry LE fourbanger, the change in the car's pickup was very noticeable when turning the AC on or off.
