Does a BTX case require a BTX power supply?
Medellon
I was given a new Gateway computer that uses a BTX motherboard and case design. I want to upgrade the graphics and need a new power supply. Do I need a BTX power supply or will an ATX one work?
What graphics card? Your current PSU may be fine for it, as most OEM's understate their PSU's. I've had a 512MB X1900 XTX running fine with a Dell PSU stated at 375W. 😀
I currently have a 300W power supply that does not have a PCI-E power line. I want to upgrade to a GeForce 7950GT.
Originally posted by: Medellon
I currently have a 300w power supply that does noy have a PCI-E power line. I want to upgrade to a GeForce 7950GT.
For a video card like that, you may want to upgrade to a PSU that has PCI-E power connectors.
Agreed. That card will suck some major juice.
Ha! Most! More like a select handful. 10 OEMs or so will rate their PSUs for less then they can actually put out.
BTW, your Dell PSU was probably OEMed by either Lite-On, Delta, or FSP. Depending on the age of the system, but those are all decent OEMs, actually FSP produces the least quality products.
If I understand, the BTX motherboards need a 24 pin connector. Some ATX power supplies have 20+4, but others have only 20. However, I think that you can get an adapter to convert them.
No, BTX is more of a case design and it only really helped Intel I am pretty sure Intel diched the idea now that they have the 65mm cores.
