I can't get my ram speed to run at the specified 800mhz. I contacted the RAM company and they mentioned that it could be a bad BIOS flash.
My system seems to be running fine. I don't want to do a BIOS flash with the same BIOS version just to find out if it really is a bad BIOS flash that's causing my RAM speed problem.
Anyone here know if a bad BIOS flash could be the reason (or if it's an even probable reason) for my RAM speed not being able to run at spec levels.
Thanks.
Thanks.
