Does a 90 degree Displayport cable exist?
DougoMan
813
In other words, one that plugs into the port and then immediately takes a 90 degree turn downward. I need one to mount my monitor flush to the wall... But as far as I can tell nobody makes such a cable. That's crazy!!!
lehtv
11,897
74
Did a quick search and all I could find was mini displayport.
What monitor is it?
fralexandr
2,295
232
www.flickr.com
delock 65382 adapter
http://www.amazon.co.uk/Delock-Adaptor-DP-Ang-65382/dp/B009HQ1B6U
edit: if for some reason the .co.uk automatically redirects to .com (i.e. you live in the US), just replace it with .co.uk (it should be ~$20 on .co.uk shipped)
product site
http://www.delock.com/produkte/G_65382/merkmale.html
40mm total length, so it'll probably pop out ~ 1"
kinda weird how pictures of it on google are significantly easier to find than the actual product...
also weird how none of the retailers for it are from the US :S...
Are there other devices connected to the monitor also? why not go with the much more common HDMI or DVI right angle connectors?
http://www.amazon.com/Monoprice-HDMI-Port-Saver-Female/dp/B001K38Z2G
bruceb
8,874
111
What about something like this one ? http://www.necdisplay.com/p/cables-adapters/ca-dp90-2
90 Deg at one end, straight display port at the other, you would then need a cable from that to
where it is going.
You can then use something like this Male / Female Displayport extension cable:
https://www.startech.com/Cables/Aud...ort-Video-Extension-Cable-Male-Female~DPEXT6L
