Made the switch from WinXP 32-bit to Vista Ultimate 64-bit on one of my rigs (E6550, 680i mobo, 2 gigs then and upgraded to 6 gigs after Vista). The CPU used to idle around 30c, never goes above 45c under load. Now, I'm seeing it go up to around 55c under load. I'm using a Coolermaster GeminiII HS with a 120mm fan. No change to the setup except for the OS and the additional RAM.
