Does 30 psi of Water = 30 psi of Air?
iamwiz82
30,772
13
pressure wise, yes. 1 lb of feathers = 1 lb of lead
EDIT: This was my f'ing lifer post.
Zenmervolt
Elite member
Oct 22, 2000
24,514
34
Good thing it was such an important and memorable post.
ZV
KK
15,903
4
I thought water itself could not be pressurized the same way air is. That is packing more water in the same area, like you can do with air.
KK
Zugzwang152
12,134
Originally posted by: minus1972
no...because water is more dense then air(?)
same pressure yes, it it takes different amounts of each to equal the same pressure (water is denser than air).
slikmunks
3,490
yeah it is... but if you ask if the volume on a container of a certain amount of water at 30psi is the same size as that certain amount of air at 30 psi, no, because water is denser than air already... and water is in liquid form, making it MUCH MUCH denser
Beattie
1,774
PSI is a unit of pressure, not density.
therefore 30 psi of water == 30 psi of anything == 30 psi of air. of course pressure is subject to things like volume and tempreture
PV=nRT
Zenmervolt
Elite member
Oct 22, 2000
24,514
34
KK
Water cannot be compressed, correct. However, someting in the water can be compressed by the weight of the water.
ZV
iamwiz82
30,772
13
ZV
story of my life
slikmunks
3,490
KK
ZV
sure it can, it just takes a LOT of pressure to compress water a little bit...
slikmunks
3,490
however, for most purposes, there's no point to compressing water, cuz it takes way too much pressure to yield a small change in volume as a result of the pressure
Zenmervolt
Elite member
Oct 22, 2000
24,514
34
KK
ZV
Well, for all practical purposes water cannot be compressed. (I'm just upset that for once I'm not the one posting with the, "well, technically..." response.) :p
ZV
Woodchuck2000
1,632
Originally posted by: VBboy
1 POUND per SQUARE INCH of anything is the same.
Well exactly! Where did all the the talk of compressing things come from?
It's like saying "Is a metre of steel the same as a metre of rope"
Moonbeam
74,134
6,612
It doesn't take different amounts of air or water to create the same pressure if you are talking about pressure created by gravity. It takes exactly the same amount. The volume is different. You could, however, because air is a gas and compressable, create 30 Lbs of pressure with a tiny amount of air by pumping it inot a configned space. Air can also be liquified with enough pressure.
