Originally posted by: Avalon
Your 12v line is used by your motherboard, cpu, and graphics card. So, in a nutshell, it's probably one of your most important rails. However, an 11.9x reading is perfectly normal, and right on the mark. There will always be slight fluctuations, no matter what combination of motherboards and powersupplies you use. I usually don't get worried until it drops down to 11.7x for an overclocking rig.
Originally posted by: Sentential
ATX specsifications call for +-10% on each rail. So long as it is within the 10% range on load then it will not be a factor.
For a stock system, sure. But, if you're overclocking, would you want your 12v rail to be at 10.8v? Even 11.4v?
10% rule is always in effect, just like gravity. I havent seen a case (yet) where over-volting helps
It's 5% now (latest spec.) :thumbsup:Originally posted by: Sentential
