Dodge Colt "turn signal" help ?
Blain
Here we go...
I've got a turn/hazard signal problem with my 89 Dodge Colt.
My left turn signal stopped flashing. I figured it was a bad bulb. I changed both side front bulbs, rears were working. The turn signal relay still works for the right side, but doesn't work when the left is on. The left rear light just stays on.
Both rear lights flash when using the hazard switch, but not the fronts.
The fuses are good.
Any suggestions?
