Just recently upgraded my internet connection to a 75mbps down and 2up profile. Had to switch over my Docsis 2.0 modem for a Cisco DPC3825 modem, this model is also a wireless router.
Plugged everything in and set it up through a hard wired connection. Consistently getting 75mbps down stable and 2 up. However I noticed this cable modem/router is very unreliable. I have many times where it just drops connection to the internet and network. I can't access the router page or internet during these times. Mind you this is through ethernet and not over wifi, I have yet to try a speed test on my wireless devices but I notice if something connects through wifi my hard wired connection becomes completely unstable.
So I tried to set the modem to bridge move and connect a router to it to see how well it works. I set it to bridge mode and connected my linksys wrt54gs to it, through the linksys router I connected my computer with an ethernet cable. I ran a speedtest and I was getting anywhere from 30-40mbps down with 2 up. This is the same with wireless connections in this configuration. Now I figured this router would be able to handle 75mbps down if it was hard wired, am I correct in thinking so? I'm completely fine with having 30-40mbps down on the wireless connections but for a hard wired connection I find that terrible.
Do you think there is a way to make the DPC3825 stable with both wired and wireless connections? Or should I go the route of bridge mode + router. If so is there a reason the wrt54gs cant support 75mbps down with a wired connection? Or does setting the modem to bridge mode somehow manage to lower the connection speed? Any help would be appreciated.
