Docks and charging port in phones
Andy T
215
I have a few docks for my Moto X that allow the phone to be upright and charging. However, there is a slight angle, so the phone leans back a little. This probably places some stress on the phone's charging port. Should I be concerned?
Thanks!
shortylickens
80,287
17,081
Thanks!
No, not if you insert it properly. Just be careful when you grab it. Dont bend the thing or it will eventually wear out and break.
Thats why I love Sony, they put flat charging pads on the side and you just have to lay it in.
shortylickens
80,287
17,081
Just plop it in.
destrekor
28,799
359
Yeah, I wish the whole "pogo pin" thing would really take off/catch on/return.
If the Galaxy Nexus wasn't so screwed up (variants for different carriers, different battery sizes), there would have been more compatible accessories. Considering I had the OEM extended battery, on the Verizon phone - I was double screwed. Some accessories were only good for non-Verizon, or any Verizon-compatible ones didn't work with the extended battery.
I think they did make one compatible, but Samsung wanted $90 for a plastic dock.
It had the pins, and I wanted to use them, but they made it ridiculous. I guess most of the Nexus phones have had the pins. My Nexus 7 (2012) has them, and a dock is available that makes use of it.
I wish those pins were more common, because it's much better for docks/cradles. Why have our smartphones largely abandoned the entire idea of a cradle, anyway? Wireless phones have always had cradles - it's the more practical approach to charging. Why we abandoned that to have to utilize small, fragile connectors , I dunno.
Sure, the ability to travel with only a cord is great. But it can't be that much to add pins, and once there, it's the better route for charging while at home or at work (wherever you want a dock).
It'll probably never be the common thing, which sucks. :(
