Ted Harris
I have just finished a clean install of Windows 7 64 bit on my computer. I backed up using Carbonite Online, Acronis True Image Home along with manual backups on a external HDD. After saving I noticed that the text all .doc extensions were "fragmented" for want of a better description. In restoring to the new system, I used portions of all three backups as I thought best. When I open .doc files on the new installation, the files are still fragmented. I can use Notepad or MS Word to open these files however I find that I can make small text changes and re-save the Doc under a new file name and the text is still fragmented. I can operate OK under these conditions however it is an impediment to efficiency. I have reinstalled clean again and the same thing happens. My old system was 32 bit, however I have been assured that the 64 bit system was the best way to go. Can anyone anylize my problem and send help?
Thanks in advance. Ted
