Originally posted by: narzy
I really am interested to see someone's kill-a-watt numbers if they have them. It would be interesting to see just how much of an impact DC has on power usage.
It will be just about the same as loading up any other application that pushes the cpu (or gpu) utilization rates to 100%.
For the vast majority of cpus out there right now the power-consumption delta between idle and fully loaded is less than 150W for even the more extreme TDP chips.
So for the folks who still use incandescent light bulbs, its about the same as turning on an extra 100W light bulb in your house. For the folks who use CFL's is about the same as turning on 4-5 100W equivalent (lumen-wise) CFL bulbs. Watching TV on a standard 27" CRT is going to use about 2-3x more electricity versus setting your otherwise idle computer to run DC.
IBM is full of it.according to IBM DC has the same effect on your energy bill than an additional light bulb
Originally posted by: taltamir
Hundreds of dollars per year is not irrelevant no matter how rich you are. It might be acceptable, but not irrelevant...Concerns over electricity costs are valid, but irrelevant to the vast majority of folks who are appreciably above the poverty line and don't live with their parents still (meaning they are beholden to someone else who pays their bills for them and so have to justify their cost footprint on the household budget).
Also, people keep on saying "cancer research". There are MANY DC projects out there, many of which don't have such well defined benefits (ex: seti@home). I assure you that folding was the LAST project I quit. If you are gonna argue for cancer cures, then state clearly that you are talking about protein folding, not DC in general.
Although I also happen to be a poor college student... (although I never buy beer, cigs, or pizza)
I Would like to point out that underclocking and undervolting a modern CPU to get the WU of an old one is... well, a waste in the relative scheme of things. DC is not a static thing, and as costs decrease, challenges tackled increase, requiring more power. Every year n, people contribute as much FLOPS as the entirety of the calculations done from inception to n-X. with X probably being 3 or 4 years. So the entirety of donations simply accelerates research by a few more years. And to be honest, it would be better to have specialized computational farms and donate 15$ a month to them, instead of running it on your own PC. Part of it is that people are not seeing the cost.
Electricy costs vary as well, (and cooling costs), and it can come up to much more than 15$ a month.
Originally posted by: totalcommand
Plus, a 15$ donation would not be the same as a 15$ electrical WU donation. Infrastructure costs/overhead for running server farms is high as well. Of your 15$ cash donation, probably half that would actually go to computational power.
Why do most people run their computers 24/7? why not set up a sleep/hibernate time?
people still use incandescent bulbs?
Because every computer I've seen doing that runs like total garbage. I hear that the on/off power surging isn't a big deal, but there seems to be some correlation between people who turn the computer off every day and having the hard drives screw up. I've been using the same 120gb 5400rpm maxtor drive for 6 years of 24/7 operation and there are no signs of it degrading. I've only ever lost 1 hard drive and it was because I dropped it on a tile floor. The hard drive failures that plague the people around me don't seem to happen on any of my 24/7 computers.
I run F@H because the computer is on anyway. If the computer is already doing file sharing and defragging and virus scanning, it might as well do some calculations on top of that. My UPS says the power difference between full load and no load on an E6600 is only about 10-20W while the whole system takes over 200W, so it's really a non issue. The case fans and hard drives take more power than the CPU does.
edit
I took a few pictures to share with the rest of the class.
Full load power: 324W
No load power: 302W
power used by F@H on both cores: 22W
The power where I live is about 11 cents per kwh. That works out to be $22 per year to run F@H all day and night.
I do. In my experience with many brands of florescent bulbs they flicker and cause headaches and eye strain. So the energy savings not worth the benefit.
flourescent? I hope you mean CFL... the CFL bulbs are very different than old style column flourescent bulbs.
anyways, the figures of 22 watt difference seem bogus to me... ESPECIALLY due to 302W idle, it should be closer to to 100 watt idle and 350 watt load.
I just finished my finals (finally), so I have time to take some measurements... tommorow, right now i gotta sleep, i am dead on my feet
My biggest problem with CFL actually is the mercury.. did you know that if it breaks you are supposed to RUN OUT OF THE ROOM and only come back to clean the debris 20 minutes later?
http://www.npr.org/templates/s...ry.php?storyId=7431198
funny that every "environmentalist" from here to kingdom come tells you to REPLACE exist bulbs with CFL (another stupid thing, the production cost of the bulb is WAY greater than the saved amount... you first let your current bulbs naturally burn out... THEN you replace them with CFL... otherwise you create MORE pollution and spend more money)
Originally posted by: elconejito
I've got a kill-a-watt and some time to burn. I'd install a DC client for testing purposes to see what idle and load are while using the client. Which one should i choose?
