Well, I have recently started having a problem with my computer. It will sometimes not power on. And sometimes when it does, it will go on for about 3 seconds, and then power off. What I have been doing is on plugging the power cord, and plugging it back in, and then flipping the power swtich off and on, and it will sometimes go on, and stay on. But now it wont do anything. The time it stays on is decreasing. I checked the AC flowing in from the cord, and its a good 115-120 Volts. The switch on back of the power supply is switched to the USA standard. I do have a poor wiring job, where it might cause, heat, but this computer has worked fine for the year that Ive had it since I built it 2 X-mases ago.
The computer is running off an AMD 64 3500+, an MSI k8n neo2 plat, a 160 Seagate HD, a 9800 pro vid card, and I have a 5.1 speaker system running off the onboard sound.
The power supply is a 420 Watt Thermaltake (it came with the thermaltake case) , and I think should be enough power, it has worked for over a year. I also havent attached any new hardware recently.
What do you think is the problem? AnythingI should try?
THANKS!!!
THANKS!!!
