monty has 3 doors
behind 1 door is a car
behind 2 doors are goats
you select a door.
monty then shows you a door with a goat behind it
he then allows you to switch
do you?
the answer is yes
i know this has come up before, but here is a really simple proof
there are only 3 ways this can be set up:
1 2 3
CGG
GCG
GGC
you always pick door 1
if you pick door 1 in the first case, monty shows you door 3. if you switch, you lose
if you pick door 1 in the second case, monty has to show you door 3. if you switch, you win
if you pick door 1 in the third case, monty has to show you door 2. if you switch, you win
i hope that is easy enough to grasp.
you select a door.
do you?
the answer is yes
1 2 3
CGG
GCG
GGC
