Do you recommend having more than 4gb of ram in a 64bit system?
Kroze
I'm building a new pc with 8gb of ram but I keep hearing people say that having 4gb is enough :hmm: and it's useless to go over that amount
Depends completely on what OS and apps you run. For WIN7-64bit, as a general guideline 4GB is enough for surfing, email, ms-office etc. For photoshop I would go with 8GB. Personally I would go with 8GB immediately, given the relatively low ram prices (assuming your budget allows it), and that WIN7 is pretty good in using all ram (free ram is used as diskcache).
On an unrelated note, an SSD is well worth it if you can afford it.
And that again depends completely on what you're doing. Having a 8gb PS workingset is quite out of the norm for most uses though - that must be quite a large file (postersize?) with some of the more complex filters.
right now with all my software running that i need, along with all my diag tools, i am using 17% of 12gigs of DDR3.
When i game, i see that number gp up to 30% at times, and when i do other stuff it goes up even higher.
The most ive used is probably 8/12gigs at one time.
So id have to say its up to your usage.
Check out windows task bar... and see how much ram you use.
4GB is more than enough for basic office tasks. 8GB is the way to go as you don't have to worry too much about having not enough space and it is pretty cheap as well. More RAM comes in handy if you're running a VM.
With prices this low for DDR3, get 2x4GB just for fun. I put 4x2GB DDR2 in my two desktops. Win7 uses, at most so far, around 3.20GB of RAM. It caches like 4GB of RAM.
Basically this.
I have 4 x 4GB modules in my machine because the price was dirt cheap and i run multiple VMs. Yeah, i use it all (almost) most of the time.
Well I use my pc for gaming (Modern Warfare/Black Ops, Battlefield 3) & general browsing/watching videos.
I should upgrade to 8gb instead of 4gb shouldn't I?
Will it help a little? Yes
Will it really make a noticeable difference in your usage? Most likely no.
Is it cheap enough an upgrade to do it? IMHO, yes, but everyone perceives value differently.
If you don't have an SSD, I would certainly rather have 4gig RAM + SSD vs 8Gig + spinning disk.
I'm gonna hijack your thread if you don't (or do 😛) mind.
I just recently picked up 8GB of G.Skill DDR3 for $63.74 for a future setup. (I'm currently using socket AM2+) How long would you all figure that amount would last? The most memory-intensive task I would be doing is probably gaming.
