Originally posted by: Number1
OK I have a 42 in 16:9 plasma 1080i TV
I like to rent movies standard size because it fills the screen.
I avoid the widescreen version like a plague because I can't stand those horizontall black bars.
Are standard size movies automaticaly stretched by my hardware? If it is I can't tell. The picture looks fine to me.
Please tell me you're joking.
What the F are you talking about?
Theatrical content can be in 16:9 or wider than 16:9 aspect ratios (like Sony CinemaScope). This is referred to as "OAR." When you buy the widescreen version, you are either getting 16:9, which will fill your screen nicely, or you are getting a wider aspect enclosed within 16:9 to maintain the OAR. Wither way, if you buy 4:3 movies and stretch to 16:9, you are BUTCHERING far more than the average idiot who would zoom on the OAR to fill the screen.
When you say that you buy "standard/Full-screen" instead of "Widescreen/OAR" you are buying for the WRONG standard. 4:3 is no longer "standard" for theatrical movies (Academy Standard). You are purposely mis-matching your screen with the movie. You movies suffer, so ignorance is NOT bliss. If you are buying HD movies, like BD and HD-DVD, there should no longer be "standard" and "wide" versions, because "standard" is NO LONGER standard.
Stanley Kubrick preferred academy aspect, and shot his films intended for that as the OAR, though the theatrical cuts were framed as wide within academy frame. In Top Gun, Tom Cruise's motorcycle fist-pumping scene had his fist and most of his body chopped off in the theater and the frame was "opened up" for 4:3 release (rather than Panned and Scanned). These situations confuse the whole OAR vs. theatrical aspect debate, but one thing is inarguable: If you have a widescreen TV, you have no business buying "standard" 4:3 content. You are throwing your money away.
If you still have bars on a widescreen DVD, your DVD player is probably not set correctly. It is shrinking the movie and adding the bars which are making it lower than standard def. You will actually get increased resolution by correcting the setting. Non-anamorphic widescreen DVDs are less common, but some do exist. These were sloppily encoded DVDs that actually record the black bars inside a 4:3 image. The only way to remove those is to zoom in to blow up the lower detail picture or demand a proper widescreen release. Though this is mostly a problem with very old widescreen DVD titles, HD formats are finally giving us that "proper" release for some movies (most, like "The Big Lebowski," got "double dip" DVD releases that fixed it).
Edit: And, yes, most plasma HDTVs stretch 4:3 content by default to avoid burn-in. You have an aspect button that can correct most SD content, thogh HD content is supposed to be 16:9 (4:3 content will be "pillarboxed" by the output device). If you had an LCD, you should always use the setting to acheive OAR. Zoom on letterboxed SD programming like NatGeo or Discovery on SD cable, set 4:3 for "full screen" SD TV shows, fill at 16:9 for HDTV broadcasts and HD sources (Blu-Ray disc, XBOX 360, HTPC, etc).
