busydude
I am sorry if this has been dealt before. I recently built an AMD system with G.Skill Ripjaws, although good, the tall heat spreaders do not clear my AC freezer pro 7 rev.2 and I had to use slot numbers 2&3. It is not so much of an issue now but I may install 2 more sticks soon because I have to process data larger than 4 GB which makes my research a bit easier.
I do not plan to overclock and I have good air flow in my case(Phenom II X2 @ 3.9 25 C idle/35C load).
My question is, will my memory kits operate without heat spreaders. The simulations sometimes run 24/7 and, from my observations, can be pretty stressful on memory.
Any help/suggestions is appreciated.
Thanks.
Thanks.
