- Apr 17, 2008
- 6,574
- 3
- 0
im thinking about getting one of these but someone told me to get a card instead because the usb one dont usually work very well. i dont see anyone using them. could you recommend a brand and model that works well?
Gotta go with that EDIMAX card, Jack recommended it to me a while back and it's worked great since then (though I think THAT particular one has a longer cable than mine [cable was just a tad short for where I had it])The small plug inn Wireless USB are OK for occasional use.
They are small and made of plastic, so their heat dissipation is Not good and they tend to warm up after prolong use. As a self protection the strength of the signal is then attenuated to avoid burning the output part of the chipset.
Thus for long use in a desktop PCI is better.
This very good - PCI http://www.newegg.com/Product/Produc...82E16833315041
Driver/Utility for Windows 98SE/Me/2K/XP/XP 64/Vista/Vista 64
http://www.edimax.us/html/english/frames/b-download.htm
If you must go USB, - http://www.newegg.com/Product/Produc...82E16833315075
