Do UPS's offer less protection against surges than most standard surge suppressors?
ddeder
1,018
I can buy a standard surge suppressor with 1800 joules of protection for about $20. I see most UPS's under $100 have only 500 or 600 joules of protection. Do I really give up surge protection if I buy a UPS or is there something about the UPS which makes it less necessary to have the higher joules rating?
ViRGE
Elite Member, Moderator Emeritus
167
While this isn't the most technical answer, UPS's tend to be backed by reputable companies with some good warentees behind them. If you went with a UPS, and a surge blew it, the company should in most cases replace the equipment, although I've never seen a UPS unable to handle a surge.
aka1nas
4,335
A UPS also has a battery backup and can often be used as a line conditioner. My midrange UPS also does its protection at up to 1500VA of load. How much do you think you can load up a $20 surge and still have it give you 1800joules of protection?
Captain4
273
From what I've heard, you're more likely to encounter an undervoltage (brownout) than a power surge. In that case, an UPS would be better.
EeyoreX
2,864
This, of course, depends somewhat on where you live. In my old neighborhood power spikes/surges were fairly common. Also in an area with frequent storms with lightning spikes/surges would be more of an issue. Either way, a UPS is superior to a "surge strip". The only things I use a surge strip for are lower power, low cost electronics. Basically, I use them to add more outlets.
\Dan
