Do they make light bulb socket converters? from small to big?
Status
Not open for further replies.
richardycc
5,719
Originally posted by: 0roo0roo
from type b to the standard size? anyone know? its because i have a compact flourescent i want to use but this one lamp has the dinky socket. very annoying:(
not sure what type b is, but if it is the same as "candle" base than you can goto my home depot, they sell a candle base flourescent bulb for around $5.
rich
Scarpozzi
26,391
1,780
I don't know what type b is either. Is there a major diff in the wattage? The problem is if you're going from a small to large or large to small, they'd have to be close to the same wattage or the bulb will blow pretty quick.
RU482
12,689
WTF are you talking about?
0roo0roo
64,795
84
i think the candle bulbs are called socket b, atleast thats what the lamp is labled as. as for wattage, the wattage ratings are meant for incadecent bulbs, so you can get away with far brighter using flourecent:)
T2T III
They must make them. A few weeks back, I purchased an adapter at Home Depot that allows me to use a type "B" bulb in a regular-sized socket. I don't see any reason why they wouldn't make them so they go the other way. Mine was in an obscure location at the the store. It was on one of the end caps near the lighting fixtures, but I had a guy helping me that knew the electrical section pretty well. You might just want to head over to your local Home Depot (assuming you have one nearby) and see what they have for you.
0roo0roo
64,795
84
sweet:) i'll check tommrow!
Eli
Super Moderator | Elite Member
8
As far as wattage goes.. You should still be careful. Yes, the wattage rating was "meant" for incandescent bulbs.. but it doesen't matter. Watts are Watts.
The CF lights themselves indeed have a wattage rating. Check for it. That said, they're very, very low... at least compared to their incandescent cousins. Just make sure it's at least the same.. and if you want to be safe, a little above.
It wouldn't surprise me at all if there were Type B bulbs that consume over 50W ..
0roo0roo
64,795
84
i think you can stick up to 35? watts incadecents into the type B fixtures i have, but well.. 35 watt flourcents would be blinding:) so i don't think it would be a problem. 20-25watt flourcents= 100watt incadecent.
Known
Here is where you can get what you are talking about, Ihave also been looking for them.
http://www.sears.com/search=Pack%20E...et%20E26%20E27
Hi,
Welcome to AnandTech Forums. I locked the thread because the last previous reply was over eleven years ago.
Our members refer to such posts as "necro" posts, and some of them tend to post replies ranging from sarcastic to hostile, including possible accusations of spamming, whether warranted or not.
You are welcome to continue posting on our forums. Thanks for understanding. We hope you enjoy yourself on our forums. :)
Harvey
Senior AnandTech Moderator/Administrator
Status
