Originally posted by: YOyoYOhowsDAjello
Chaintech AV710 has it, but it's not the best gaming card.
You can also make your own cable to make a connection to an A2 from what I've seen.
If you have the cash, you can get a Audigy/X-Fi along with the AV710. Set the Audigy/X-Fi as your default card in Windows so all games will use it and then set your media players to use the 710 for input/output.
I had a similar set up a while ago where I had my SB Live! go to my speakers and my onboard sound go out to a TV. Games and Windows Media player would use my SB Live! for output so I could play games and watch stuff on my monitor. Media Player Classic would output to my TV so I could watch movies that way too.
I am exactly having the same question... using both onboard audio and a discrete audio card at the same time. I would use an X-fi music for everything but I/O and then connect the front panel ports to the motherboard audio module. Would it work?
You can do that, but probably not with the fancy Creative Labs front panel. A lot of cases already have built in Mic/Headphone jacks that can easily connect to motherboards with onboard audio. You just plug the front panel connectors to the audio connectors on the motherboard. If your case doesn't have built in jacks, you can easily find front panel that will fit into a drive bay and do the same thing.
So.. your advice is to connect the case ports to the motherboard plugs and use both cards at the same time? Disabling the onboard sound module would also disconnect the ports?
Yeah. That'll work fine. That's exactly what I've been doing with my Shuttle XPC. I have 3 front ports that use my onboard sound, and I also have an SB Live!. The SB Live! is used for stuff that needs higher quality sound like games and my computer speakers. My onboard sound goes out to my crappy 19" TV.
Hey thanks a lot for the informations!
Does the OS take care of everything or you need some third party utility to get this setup work?
You'll need to tell your video/audio players which soundcard you want them to use. You should also make sure to tell Windows which soundcard you want as default. Those settings can be found under Control Panel -> Sounds and Audio Devices.
I have my SB Live! set as the default soundcard in Windows so games will automatically use it. I also have Foobar (my mp3 player) use the SB Live!. I have MPC (my video player) set to use my onboard, and WMP (my other video player) uses my SB Live!. You can find the settings for each program under their own options/settings.
Sorry to bother you again... you have been incredibly helpfull!
Do I need to do anything in the BIOS or just assign a soundcard as the default and then assign one card to each program?
Thanks again!
