Do software coolers work? HOW do they work?
LS20
Banned
Jan 22, 2002
5,858
For example, the program CPUIdle
I'm skeptical..how can a software reduce the temperature on the physical cpu?
S0me1X
1,480
CPUIdle was for older versions of Windows. It basically runs HLT at idle priority. Windows 2000/XP has an "idle" thread, so you don't need CPUIdle.
Brian48
3,410
They "cool" the processor by issuing HLT commands to CPU during periods of idle. Essentially putting some of the processes in suspend mode when you're not using them. Because of less activity, less electricity is used, thereby less heat. These programs originally were designed to extend battery life on laptops, but then some developers starting applying this principal to desktop PC's running Win9x to take advantage of the cooling benefits, which is really a secondary side effect of the original purpose of conserving power. WinNT and similar kernel OS's have always had this built in, why it was never implemented into Win9x? Who knows.
Anyway, these programs should only be considered strictly as supplementary cooling and not a replacement for a decent HSF. They are only good for keeping the CPU cool during idle or low activity periods. They do nothing for you when your processor is actually performing heavy tasks (ie. gaming). They do, however, aid in quickly bringing the temp down once you're through though.
I personally don't think they're worth it these days, even under Win9x. This is especially true for K7 AMD systems since HLT command functions are already enabled by default in the BIOS (for old Athlon MB's). Newer Athlon motherboards do not allow HLT functions at all regardless of what program or OS you run. This has been disabled because some faster (1.2ghz or higher) systems have a problem with the sharp power spikes cause whenever the system jumps back and forth from activity levels. Doesn't happen to everyone, but there's enough of a problem that AMD has recommended it disabled and MB manufacter's have followed suit. VIA users can of course, by pass this restriction with 3rd party utilities likes Wcredit.
Akira13
708
I used Rain on my Celeron 400mhz laptop (Dell Inspiron 3500). Before using the software, the CPU fan would go on after 30 minutes of use, but now rarely goes on at all. Good stuff, especially if you're trying to save battery life and your ears.
Lark888
1,032
I second the vote for Rain 2.0 - This is a small, low overhead program that you can load in your Start folder. It substantially reduces the CPU temperature in Win9x versions on Celerons, PIII's, AMD K6s, etc. There is no measureable performance hit, the program is free and will keep your chip cooler most of the time (like surfing, sitting, playing MP3s, etc).
HOWEVER - I also second the position that it is NOT a substitute for good HSF and Thermal interface compound. These programs will not reduce the peak temperatures that are achieved during full load applications (like running Quake, CS, and other 3D applications).
Running Motherboard Monitor - you can see the CPU temps drop immediately following starting Rain and then stay lower. This is especially true for a K6-3+ chip I have running at 600Mhz - that one drops about 8C and since I only use it for office work and web stuff, the Rain program keeps the temperature lower all the time.
