Do small scratches on HS make big temp. difference??
mato7742
i've got a thermalright slk900-a w/ a vantec tornado and my temps with the fan all the way up are around 40C idle. of course, however, i don't leave the fan all the way up when it's idle, i actually turn it down all the way with the vantec nexus and it goes up to about 45 idle when the room is warm. when i first got this hs a while ago i had trouble installing it and i think i made two minor scratches on the bottom of the hs directly above where the cpu goes. does anyone think this could be making a large difference on my temperatures?? these temps are only slightly better than what i was getting with the vantec aeroflow (a couple of degrees). should i sand down the hs to lower the temps?
small scratches shouldn't adversely affect cooling performance if you've applied your thermal paste correctly.
is the hs mounted correctly?
Small scratches are fine. The thermal paste is designed to fill in any "hills and valleys" in the heatsink base or CPU core as long as they aren't huge gouges 😉. If you're worried, you can put a little tiny dab of TIM on the base of the heatsink, put a plastic bag over your finger and rub the goo into the heatsink to fill any abnormalities.
BTW, You shouldn't be worried about those temps anyways, they're well within spec.
i tried rubbing it in before, then i tried just globbing it on like the as5 website recommended for as5. they said the older versions of as needed to be rubbed in, but the new 5 is so thick that it doesn't. temps are around the same though. hmm. oh yeah, the as5 never brought down my temps any way i tried putting it on. any reason why?
