R Raspewtin Diamond Member Nov 16, 1999 3,634 0 0 Jul 23, 2001 #1 or does the heatsink come seperately? can you remove the heatsink or is it glued on? thanks!
J j24u Senior member Jan 2, 2001 842 0 0 Jul 23, 2001 #2 They are separate, unless you order a Motherboard also. Most places will put the CPU on the MOBO and attach the HSF.
