Originally posted by: Raybdbomb
I was wondering if a PSU can, by itself, aid in cooling or make the computer hotter. Specifically speaking: I have a P.O.S power supply from englight (i think) and was thinkin about getting a better one due to it sucking gonads
In a word YES!
I have one PC that was running exceptionally hot. The case temp was over 30C.
I replaced the power supply fan and case temp dropped 6C!
I have since replaced the power supply with a better unit and I have no heat issues with that system anymore.
Reach behind your computer and feel how hot the air excaping from your power supply is.
A more efficient power supply will generate less heat than a less efficient one. It also needs to be able to effectively remove the heat that it creates.
I like the power supply I picked up for my wife's computer. It is a 350W Forton with a single 120mm fan for heat removal. NewEgg sell em. I did have to modify her case a little bit though. The 120mm fan grill was making contact with a lip that is under the porer supply causing it to not fit flush. Once I removed the lip with my Dremel things were great.
