Leaving it plugged in is not a problem. Some misinformed people still suggest unplugging when fully charged and using the battery to a low charge before plugging in again. Don't do that. Charging from a low state heats up the battery a lot. AFAIK, heat is the fastest way to kill a battery. A normal phone that's plugged in and fully charged should be completely cool to the touch if it's not being used.
The only danger is if a lithium battery for some reason allows you to completely drain it dead, it may not charge again.
Shabby, it came from peoples whos devices discharged and would no longer charge again. It is not a %100 thing, and I "could" say the reason the battery died and would no longer take a charge is BECAUSE the battery is damaged and will no longer take a charge, but either way it should be avoided if not for the sake running out of power when you actually need to use it. 🙂
Scientists at Nanyang Technology University (NTU) have developed ultra-fast charging batteries that can be recharged up to 70 per cent in only two minutes.
The new generation batteries also have a long lifespan of over 20 years, more than 10 times compared to existing lithium-ion batteries.
This breakthrough has a wide-ranging impact on all industries, especially for electric vehicles, where consumers are put off by the long recharge times and its limited battery life.
It's amazing how people thinks their own baseless intuitions about batteries is more credible than the knowledge of the EEs who designed these things in the first place.
