- Feb 11, 2005
- 7,942
- 2
- 0
I only ask since if you come to a hill or something an automatic will shift up as it works harder to go up-hill...does a manual on cruise control just read line the ish out of the car so you don't have to shift?
Originally posted by: Colt45
How do you figure it's going to redline it with the car in gear?
Theres no torque converter. Wheel speed is directly proportional to engine speed.
Originally posted by: MrPickins
I've never tried using the cruise control in my Ranger in any gear other than 5th.
Now that you've got me curious, I think I'll try out how it works in other scenarios
It won't matter. If in fifth, to do 50Mph you need 2100 rpm, then that is what it will stay at. No more, no less. If the same vehicle needs 3500 rpm in fourth to do 50 mph, then that is what the CC will hold at. End of.
So what if you're in first gear and hit resume?
Most modern CC systems will not engage below 30 mph. How often are you going 30 mph in 1st?
ZV
ZV
ZV
You kind of missed my point there.
My point was whether the cruise control would rev the engine to redline trying to maintain the set speed. My example was if you you set the cruise control in a higher gear and then tried to resume it in a lower gear.
I just took my Z out to see what it would do, and it will in fact rev the hell out of the engine trying to reach that speed. I set it at 60 mph in 4th gear and then resumed it in 2nd gear. It climbed above 6000 rpm before I hit the brake to disengage it.
For the record, first gear will reach about 45 mph.
Originally posted by: TheNewbie
CC is meant to be used only on a freeway (or otherwise a road), where you can maintain your (fairly high) speed for a while. Climbing mountains usually involves snake shaped roads which means you have to slow down anyway, so CC would disengage also on an automatic car.
Originally posted by: Pliablemoose
Now for the real test, someone needs to go in reverse & press "resume" :evil:
