Do Logitech z 5500's come with a digital optical cable?
song414
Do the 5500's come with any audio cable connectors out of the box or do i have to buy a digital optical cable? Do they come with any other cables to connect the speakers to a sound card or audio device?
afaik they come with the three 3.5mm stereo cables you'd need to connect to a computer.
Digital optical and digital coaxial would not be included.
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10229&style=
If you want to do digital coaxial, keep in mind that it's just a standard 75ohm cable with RCA ends. A composite video cable (yellow with RCA ends) should work just as well as a "digital coaxial" cable.
Also keep in mind that if this is strictly for connecting to a computer, hooking up with analog tends to usually be the better connection method than digital.
Does not come with a optical cable. I have the speakers in question and had to purchase an optical cable separate.
