I bought a small grease gun that takes 3oz tubes (~6 inches long)
The gun came with a tube of Pennzoil MultiPurpose 302 EP Grease with Moly (NLGI #2 Lithium based grease containing moly disulfide). I noticed on the label, quote "Automotive applications include steering, chassis, suspension parts, ball joints and wheel bearings of vehicles equipped with conventional brakes (not disc brakes). Use Pennzoil Premium wheel bearing 707L Red Grease to lubricate wheel bearigs in vehicles equipped with disc brakes or ABS."
Anyway, on to my questions.
1) Do you have to lube the grease points at every oil change?
2) Anyone know where I can get small tubes of red grease? My local stores don't carry it.
3) What is the meaning of life??
Thanks
Thanks
