Do I really need an EPS 12v power supply for Sandy Bridge?
techs
28,559
4
The Sandy Bridge mobo's come with the 8 pin power connector for the cpu. I have noticed that at least one mobo says you can use a 4 pin.
So, is the 8 pin connector a must or can I upgrade to Sandy Bridge without upgrading my power supply?
Thanks.
Bryf50
1,429
51
My extreme4 had a sticker covering half the connector. It said it was optional.
dma0991
2,723
Well, that's pretty bizarre.
It's normal for any motherboard with 8 pin EPS socket. For normal use most would not need 8 pin EPS and only 4 pins are need. If you overclock and your motherboard needs more power then the 8 pin comes in handy. All 8 pin EPS breaks apart with 4+4 pin.
techs
28,559
4
Ah, that explains it.
wwswimming
Banned
Jan 21, 2006
3,695
Thanks.
one of the hallmarks of Sandy Bridge is the low power consumption.
the 8 pin connectors are the kind of thing you needed in 2003 for a dual-Xeon space-heater.
so probably ... you're safe just using the 4 pin connector.
VirtualLarry
56,587
10,225
You can use the 4-pin plugged into half of the 8-pin socket, but I wouldn't overclock unless I was using an 8-pin connector.
mb103051
280
use the adapter and all power feeds are powered up...ive used them on several mobo's and they work fine....just bugs me knowing 4 of the power feeds has no power....ive used the first one listed as i just plugged the 4 pin on the power supply to the 4 pin on the adapter and then plug the 8 pin into the motherboard...ive also in some cases just soldered the 8 pin into the harness to avoid the connector resistence and didnt want to see the adapter hanging in a windowed case....
GuitarDaddy
11,465
I recently bought an MSI P67 board and it had a cap covering 1/2 of the 8pin connector, I used an older PS with the 4pin and overclocked it with no problems whatsoever.
