I have a p4 2.4 system with an MSI 845GE motherboard (integrated graphics), stock intel heatsink and fan on cpu, Western Digital 80GB 7200rpm hard drive, in an Antek 630II case. My system is not overclocked, and I may or may not mildly overclock in the future.
I have the Antek case fan that came with the case installed and running, and the noise bugs me.
Two questions...
1) Do I really need to run it? (or is the power supply exhaust fan enough for my set up)?
2) If so, is there a significantly quieter (or silent) case fan that isn't too expensive?
I looked at the Vantec SF8025L Stealth Double Ball Bearing Case Fan Retail for about $11 at googlegear. Anyone know if it is quieter or silent compare to the Antek? I would hate to get it and find out that there is very little difference in noise.
I ran the computer briefly without the case fan running, and am much happier with the noise level that way (just power supply and cpu fan).
Appreciate all comments on need for fan and if so, real world experience on what case fans are quieter than the Antek.
Thanks In Advance!
Two questions...
Thanks In Advance!
