Completely first time I've ever put together a new computer from scratch and I'm having problems. I just installed a new motherboard and now I'm having problems getting the computer to start. It acts as though it has no power but if I start unhooking items like the video card then it will although sometimes it takes me hitting the power button a few times. I'm guessing its because I'm not supplying enough power to the motherboard but I wanted to check here first to see if others agreed.
Heres what I have installed:
AMD Sempron 2800+
ATI Radeon 9600
Sound Blaster
CD ROM
DVD
768 RAM
Standard Modem
3 fans including heat sink fan over CPU
The power supply is 300W, everything worked seemingly just fine on my old motherboard which was a standard issue mobo from a store bought eMachine. The new motherboard is an MSI MK4AM-V. If this is not enough power, what would you guys recommend?
[edit] I changed the motherboard name from ASI to MSI [/edit]
AMD Sempron 2800+
ATI Radeon 9600
Sound Blaster
CD ROM
DVD
768 RAM
Standard Modem
