My present computer is a Pll 450 using a TNT 1 graphics card and is due for an upgrade
I have ordered a Athlon lGhz,, Nvidia Ge Force GTS 2, 256 Ram system . ( Blow the savings you only live once)
The Pll isn?t worth selling, It has a fault whereby I cannot get into the display properties of the graphics card. Many efforts have been tried but I have given up on that
I wish to keep the P ll and to
a) transfer some internet downloaded files from it to the new computer.
b) Use either one of the computers on the internet
c) Maybe play head to head Flight sims with my grandson and/or friends
I believe I have two options and I need advice please
My modem is an external USB model so I could put the internet dial up settings on my new computer, use a hub to connect the modem to both computers, and then have a choice as to which computer to switch on and access the internet . I could buy a zip drive to transfer the files; and forego the head to head flight sim sessions!
Or
I could buy a networking kit ? peer to peer- and join the two computers on a network including shared connection to the internet. I am completely new to networking but I think I can set this up with a step by step guide from a magazine etc.
The latter option seems to be the thing to do, but it raises one or two important points, which is where I need the advice. Please advise re these questions.
1. When I use the new computer to play flight sims online, ie connection through the Pll 450 , will the specs of the computer be those of the Pll 450 or the new Athlon 1 Ghz. You can appreciate that I want the game to use the Athlon specs! ( The first option would ensure that, would it not? ).
2. My Pll 450 uses windows 98SE and the new computer comes with Windows ME already loaded ( recovery disc only ) Does the fact that two different Windows are running pose any problem?
3. The small print of the new computer says that any third party items fitted into the computer will invalidate the warranty ( 1 years onsite ) . Does fitting a network card amount to that.? I know it shouldn?t in a fair world but what is the reality?
What do you experts recommend?
Thank you for your patience and I can see the smiles at the naiveté of the questions , but I am relatively old ( still beat most of you at golf though- lol ) and I am no techie. It will take all my efforts to set up a networking kit, but I only want to go that route if it?s the right way to go.
Thank you again
Or
Thank you again
