Do I need to use the Asus EZ Plug if I'm using a 24-pin ATX power connector?
BroadbandGamer
976
I don't think I need to use the 12V 4-pin EZ_PLUG if I'm using a 24-pin connctor but I'm not sure. Can someone confirm this?
Siddy
75
Good question, i asked the opposite then i got my board, and psu which is 20 pin, with an 4 pin as well.
the answer is yes, it is better, especially for o/c!!
raftman
270
I don't know anything about the EZ Plug, but if it's the 4-pin connector to give extra power to the CPU, I would recommend using it.
Since you are using the 24-pin connector, this isn't a question about the 4 extra pins you would see on the mobo if you were using a 20-pin connector from the PSU. To be clear, you don't need THOSE 4 pins (unless you are using PCI-E and your card doesn't have it's own power connector).
This might be a good reference.
alpha88
877
The ASUS A8N-SLI Premium has 3 different power plugs
1 x 24 pin -- Need (but the 20 pin works)
1 x 4 (square) pin CPU 12V ATX -- Need
1 x 4 pin EZ Plug (which most people call a Molex) -- Recommended if running 2 video cards, other wise optional
AndyD2k
824
Taken from 6-5 of the manual...
"If using a 20-pin ATX power connector, connect a 4-pin ATX power cable to the EZ Plug labeled EZ_PLUG on your motherboard"
