Do I need to put on thermal gel?
LuckyTaxi
6,044
23
Just bought an Athlon XP 1800 processor. Do I need to put some thermal gel on the processor?
jarsoffart
1,832
If you are talking about Thermal Interface Material, you don't need to, but it helps lower temperatures like 2 C i think? The previous was a run on sentence.
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,686
You definitely need some kind of thermal transfer material between the heatsink and processor. The stock sinks have a square of pink thermal interface material, usually covered with plastic tape to protect it during shipping. peel off the tape, install. If there's no interface pad, then definitely use some heatsink compound- just a very thin layer on the surface of the cpu die in the middle of the processor package.
Never power up a cpu without a properly installed heatsink- poof!
Zim Hosein
Super Moderator | Elite Member
65,461
408
Sorry jarsoffart, but you must use a TIM either the square pad that comes w/ the CUP, or something like AS3. For complete instruction on AS3, click Here :)
LuckyTaxi
6,044
23
I had to peel a cover off the heatsink before I placed it on the CPU. There was something still stuck on the heatsink. I assume I'm ready to go?
Woehlck
Arctic Silver III ! Never skimp out on CPU cooling - especially when it is something as simple as quality paste/gel/TIM (etc.....)
