[*] If you have a Retail copy of XP, you will only need to call if you are prompted to activate.
[*]If you have OEM then you are supposed to purchase a new copy of the OS since it is tied to your old system. This is why OEM software is cheaper, but this is also why it's a good idea to buy Retail unless you're into piracy.
