Nah. IF you do get fans get a Panaflo/Papst/Nexus/Yate Loon low speed though. That case is quiet as all hell so ...... a loud fan would make your P180 a waste 😉.
The case uses an 80mm fan for the air duct. The air duct itself is pretty much useless, and you have to have a 80x80x20mm fan for it, a standard 80x80x25mm fan won't fit with current-gen video cards.
