Nvidiaguy07
My old laptop actually still runs ok, but I think the fan is dying inside. When using normally, you can hear the fan making noises. The noises sounds like an old hard drive, but a little louder. The laptop runs HOT. When using normally, you can feel the heat on your hand. When playing a game, your hand is on fire if its near the side vent (hey at least the fan is still blowing out some air).
Installed coretemp to monitor temp, and ran prime95 to see how hot this thing gets. After 1-2mins, one core is around 95C and the other core is at 85. It gets so hot it gets to a point where it gets scaled down from 2.4ghz to 1.6, or possibly lower so it doesnt overheat. Without running any apps, the temp is 74c and 64c.
The laptop is an MSI 1651, which is a barebones version of the gx620. Its a decent performer, so I was planning on giving it to a younger cousin who plays dota and garrys mod and crap like that.
Does this sound like just the fan needs to be replaced, or does the cpu need to be reseated as well? The back is pretty easily assesible, so i dont think it should be that hard. Worth it? and can i trust ebay to get me the right part?
I was thinking of getting this: http://www.ebay.com/itm/New-CPU-Coo...?pt=US_CPU_Fans_Heatsinks&hash=item27d5d8fbdc
or this: http://www.ebay.com/itm/New-CPU-Coo...750?pt=LH_DefaultDomain_0&hash=item2c84aa8146
