bleucharm28
Hey guys, i need some advice here. I had recently added a 240 xspc rad and GTX 580 HC2 card. Do I or should I add another pump to the build?
I hear this light humming sound coming from the pump and im not sure if is my loop that causing the issue or is it even an issue? Temp are nice, nothing changed.
LOOP: Sbridge>N bridge>Mofsets>CPU>GPU>Res>Pump>480rad>240rad...(Sbridge)
idle temps: CPU 39C GPU 30C +/- 2 or 3 depending on ambient temperatures.
