Do I need more power?
EvilSponge
747
Hello all,
I recently purchased an Antec 900 case
and swapped all my existing gear into it
now I'm having issues with my over clock.
Before I was able to OC my E2160 to 3.2ghz
Now the best I can do 2.8ghz
I'm wondering if I need a new power supply?
I am using an Enhance 80 plus 500W power supply
Here is the rest of my components
E2160 CPU
Abit IP35-E
2 sticks gskill 2gig each
Nvidia GTX
SB XFI
4 x 120MM fan
1 200mm fan
-Eric
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
Not that using an 8800 GTX with a 500W PSU would be my first choice, if you were overloading the PSU it would shut down.
If all of the parts are the same and all you did was swap everything into a different case, why would the PSU be suspect? My first thought would be something got zapped by ESD during the transplant.
EvilSponge
747
My reasoning is Antec900 has more 120mm fans than I had before also one big 200mm one
-Eric
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
Yeah... I personally don't think a few fans at < 0.7A each isn't going to make that much of a difference.
But if you think it's that, unplug the fans and try it and see how it goes. Just leave one intake, one exhaust, and leave the side panel open.
EvilSponge
747
Ok got everything back I used the power supply calculator apparently when you consider capacitor aging for the way I use my PC I need a 600W supply I guess now for the next question who's a good brand these days?
-Eric
Big Lar
6,330
Well, all kidding aside, ask jonnyGURU. He just happens to be the Power Supply Guru around here and I would personally Highly value his judgement.
Larry
EvilSponge
747
Cool well thanks for taking the time Jonney! BTW you were right diodn''t make a bit of difference. I used the power calculator and it seems when I add in the aging of the caps it says I need a 600w supply do people agree?
-Eric
EvilSponge
747
Well based on what you said running a 500w supply with a gtx wasn't a good idea I just ordered an OCZ 700w that should end my power issues :)
-Eric
